Eddy dissipation model
Old   June 7, 2004, 10:46
Default Eddy dissipation model
ioana
Hi everybody!
I can't understand the following description from the help: In the Eddy Dissipation model, the rate of progress of elementary reaction k is determined by the smaller of the two following expressions:
Reactants limiter: Rk=A*EPSILON/k*([I]/niukI') , where [I] is the molar concentration of component I and I only includes the reactants components.
Products limiter: Rk= A*B*EPSILON/k*(sump[I]Wi/sump(niukI''WI)) where P loops over all product components in the elementary reaction k. The product limiter may be disabled by setting the model coefficient B to a negative value. For multi-step reaction schemes it is turned off by default, but may be turned on by explicitly setting the model coefficient B to a positive value (although this is not recommended).
Can anyone help? ioana
Old   June 10, 2004, 15:15
Default Re: Eddy dissipation model
mstein
It is all right what you are saying, but what is you're question?
Eddy Dissipation Model Enots CFX 11 August 12, 2011 05:11
EDDY DISSIPATION MODEL PID CFX 0 July 22, 2008 19:52
PrePDF or Eddy Dissipation Mark FLUENT 5 March 7, 2003 13:08
temperature too high in eddy dissipation Peter Lemtis FLUENT 3 November 24, 2002 01:45
EDDY BREAK UP MODEL GACEM hatem Phoenics 0 August 22, 2000 12:06
