May 21, 2004, 13:25 |
Gambit->CFX 5.5
I make a structured mesh model in Gambit, and the total mesh cells reach 2 million. When I export it as ANSYS format into CFX 5.5 build, a error occurs. I guess the problem would be the model is too large to beyond the limit of CFX build, for smaller mesh model is OK. Is there any better way for exporting mesh from Gambit to CFX? thanks.
May 23, 2004, 01:21 |
Re: Gambit->CFX 5.5
CGNS straight into CFX-Pre? You might have to wait a couple weeks for 5.7. Haven't tried this myself.
Jeff |
May 23, 2004, 23:15 |
Re: Gambit->CFX 5.5
Size shouldn't be an issue. I agree with Jeff, look to get 5.7. If you have a maintained license, you can download 5.7 right now.
Cheers, Derrek |
May 24, 2004, 01:37 |
Re: Gambit->CFX 5.5
Hi, There is an un-official way out... Go to T-grid and export the mesh in "Neutral" format. You can import the mesh in neutral format into pre. You neednot go to build/ansys for this. Note that there is a bug in gambit, so if u export the file in neutral format from Gambit directly it will not work in pre. You will have to export the mesh from T-Grid only
Hope this helps. |
June 22, 2004, 01:01 |
Re: Gambit->CFX 5.5
Except that the neutral file is a text file and this will be massive for a two million node mesh. Imagine the element topology alone...
Neale |
August 31, 2004, 04:55 |
Re: Gambit->CFX 5.5
How is a Gambit file transferred to CFX for solving
Gambit Startup Window | Jay Shim | FLUENT | 2 | February 12, 2015 15:05 |
How to open a saved Gambit File? | barkan | FLUENT | 5 | September 1, 2012 06:53 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 07:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 13:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 09:33 |
