Sources for multiphase multicomponent reaction sys
Old   May 18, 2004, 05:57
Default Sources for multiphase multicomponent reaction sys
Liwau
Dear Specialists,
I have trouble in setting sources for a multiphase multicompoent reaction system. The system likes this: gas + solid; reactions occur in gas phase; mass transfer exists between gas phase and solid phase. Of course, solid phase should be looked as liquid because Euler approach is adopted. When setting Fluid Sources, I don't know how to set the items under the Continuity Frame. Could anybody tell me the guidances? Thanks.
Liwau
Old   May 19, 2004, 01:41
Default Re: Sources for multiphase multicomponent reaction
test
Well I am not sure if you are using CFX-5.6 or 5.7! Assuming that you are using 5.6... You are talking of a phasic reaction... The reaction has to b broken down into steps!
1. Devolatilization of volatiles from the solid phase 2. Combustion of volatiles in gas phase 3. Combustion of char left from in the solid phase.
I am not sure what kind of reactor you are looking at.. However you can contact your local CFX support team and ask them to give you an example problem of bio-mass combustion.. It would be difficult to explain you the details in the mail now, since this analysis is very involved. You ahve to create lot of subdomain and define the source term only in the continuity equation.
Let me know if you require further help
Old   May 20, 2004, 12:36
Phil
The use of multiple subdomains for this type of calculation is now unnecessary in CFX-5.7. There is a new option to respect the specified mass fractions even if the mass source is negative.
Old   May 21, 2004, 00:08
tec
Dear test:
As your description for this problem, I want to use CFX4 to model the devolatilization of volatiles from the solid phase 2. Should I use User Fortran (which one) and how to deal with the .fc file simulataneously ?
Furthermore, I also need to track the history of solid phase 2 (char) in the flow field.
Thanks for your attention.
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
reaction in UDF(DEFINE_VR_RATE) louiza FLUENT 3 October 14, 2010 00:59
Reaction help!! Harry CFX 4 October 30, 2008 11:11
Multicomponent Multiphase Reaction Modelling Anirban CFX 0 April 17, 2006 09:51
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
