July 4, 2018, 06:40 |
Stage interface doesn't work as intend?
Oskar
Rep Power: 11 |
Dear CFX Users,
I'm using CFX 16 and I'm facing strange behavior of stage interface in CFX Turbomachinery simulation of Axial Turbine. I believe it could be cause by mesh or bad settings. Please, see the attachments. velocity1.png and mesh1.png shows velocity and mesh on the stator side of interface. velocity2.png and mesh2.png shows circumferential averaged velocity and mesh on the rotor side of interface. I do not really understand why there is such a large region with close-to-zero velocity on the rotor side. I will appreciate any suggestions, Oskar |
July 9, 2018, 05:25 |
Rep Power: 18 |
Increase number of circumferential bands.
EXPERT PARAMETERS: force intersection = t ggi stage groups max = 250 END |
July 9, 2018, 11:59 |
Oskar
Rep Power: 11 |
Dear Mister Ludvik.
I haven't tried it yet but I think You are right. I'm going to try it as fast as possible to ensure Your solution is right. Thank Your very much. Sheaker |
December 17, 2018, 14:05 |
Oskar
Rep Power: 11 |
Dear Ludvik,
after many attempts I still don't now where to set "ggi stage groups max = 250". Could You possibly point me where to set it? Best regards, Oskar |
December 17, 2018, 16:50 |
Rep Power: 144 |
It is an expert parameter. Not all expert parameters are on the CFX-Pre GUI, many are CCL only. If you use Ludvik's CCL in your CCL it should work.
December 17, 2018, 17:20 |
#6 | |
Oskar
Rep Power: 11 |
Thank You for Your answer, horrocks. I'm going to set it in CCL. (I don't know how to do it yet but I think I can figure it out by myself.) Regards, Oskar I think it does not resolve my problem. I have created CCL file: Code:
FLOW: Flow Analysis 1 EXPERT PARAMETERS: force intersection = t ggi stage groups max = 250 END END COMMAND FILE: Version = 16.0 END
How to set two stroke engine with scavenging? Salome, sliding interface and "Zero length edge detected." Last edited by sheaker; December 18, 2018 at 01:33. |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
How to use the CFX periodic interface | zhihuawan | CFX | 61 | January 15, 2018 17:20 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
Total Energy and a Stage Interface | aerost | CFX | 1 | November 16, 2011 19:51 |
