July 1, 2018, 06:59 |
Free surface simulation for resistance ship
Rizal Zulqur
Rep Power: 8 |
I am Rizal, from Indonesia
now i am doing my thesis project by using CFD ansys 16 version. i intend to generate free surface simulation to predict ship resistance. the boundary condition in tutorial in term "free surface over bump" does not show good result. the simulation is always not finish. any body can help for explaining boundary condition used in free surface ship simulation in CFX? and may be also showing physical model that can be adopt? Thank you Regard* Rizal |
July 1, 2018, 07:26 |
Rep Power: 144 |
When I have done this sort of thing I used a normal outlet boundary with a defined pressure. Note you need to correct it for the hydrostatic head in the water versus air sections.
Also: consider the open source CFD code gerris. It is a little bit different and takes some time to get used to, but it can do an excellent job on ship wave patterns and wave resistance. But note that it does not a turbulence model so cannot model frictional resistance. But it has a tutorial example on wave making resistance on a yacht and it is very easy to use for this case (FAR easier than CFX) that it has to be considered.
July 2, 2018, 04:47 |
Rizal Zulqur
Rep Power: 8 |
How about the boundary condition? What should i do?
July 2, 2018, 08:01 |
#4 | |
Rep Power: 144 |
July 2, 2018, 22:22 |
Rizal Zulqur
Rep Power: 8 |
Can you give a physical model that can be adopt? I am so Confused, because in result, water level not appropriate with UpH. I use CCL ini setup same with tutorial.
February 19, 2019, 07:26 |
How to capture better curvature of a model
sriram
Rep Power: 10 |
I am running a Multi-phase simulation for calculating a boat's resistance. I am having difficulty in capturing the hull's curvature. Suggest me a better mesh condition.
February 21, 2019, 03:46 |
How to view wave propagation
sriram
Rep Power: 10 |
It is a multiphase problem(air and water).
Initial velocity zero for both phase. I want to run a simulation for 1m/s velocity of both phases and view wave pattern. Please find the attachment. The residuals are converged, but I can't find the entire wave pattern. Give me some suggestions. |
[snappyHexMesh] Mesh around ship with appropriate free surface refinement | Hannes_Kiel | OpenFOAM Meshing & Mesh Conversion | 46 | October 4, 2019 08:28 |
Free surface comes above the hull of the ship | Sachin m | OpenFOAM Pre-Processing | 0 | September 4, 2014 01:08 |
Multi-phase free surface ship flow computational domain size | kilroy | Main CFD Forum | 0 | December 20, 2013 10:41 |
How to plot the wave contour in ship flow (free surface) problem | deddy1973 | CFX | 6 | February 19, 2013 06:49 |
free surface around a ship hull | Stephy | OpenFOAM Running, Solving & CFD | 12 | April 24, 2012 02:12 |
