abdullah ghifari
Rep Power: 8 ![]() |
dear
I am finishing an academic paper and I use CFX. I have a characteristic curve pump, whether with a characteristic curve pump we can get the actual pump geometry, using a characteristic curve pump. how to use vista cpd using a characteristic curve pump. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
No you cannot. At least not without a lot of assumptions, and even then it becomes an inverse problem (https://en.wikipedia.org/wiki/Inverse_problem) which are challenging at the best of times.
MGE_CFD
dear abdg
could start by means of hypotheses, from the beginning could insert in the CPD view the values of the pump BEP. simulate two points above and two below and power check and NPSH. It will be very laborious and I believe that theoretical values in relation to the angles of entry and exit will help. |
abdullah ghifari
dear my friend
could you please give me the steps? i am new in vista cpd and cfx please help me my friend |
[ICEM] O-grid around wing geometry | Anorky | ANSYS Meshing & Geometry | 15 | November 27, 2017 13:43 |
Fill CAD Geometry | voldemort | Autodesk Simulation CFD | 0 | July 12, 2016 01:47 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
Virtual/Real geometry. | Jack Keays | FLUENT | 9 | June 15, 2000 23:39 |
