Temp of dew point
Old   June 26, 2018, 04:13
Default Temp of dew point
chris
nasdak is on a distinguished road
Hello
I deal with flue gas flow in the industrial chimney. My goal is to identify zones where the condansation occurs. I use wall condensation model and defined air as an noncondansable and water as a vapor-liquid.
My problem is the temperature of dew point for this mixture is 60 C, and for the real gas is 140 C (this temperature I can approximate)
Here is the quastion how can I change the temperature of the dew point?
Places where the temperature drops below dew point temp I can verify with experiment.
Thanks for help
nasdak is offline   Reply With Quote
Old   June 26, 2018, 06:49
The dew point is a function of the amount of water vapour in the air and pressure. So if you simply want to know where a chimney design is going to condense, can't you just run a simple single phase model and look for where the temperature drops below the dew point? In other words, you don't need to model condensation at all.
To answer your question: You can change the dew point by changing the water vapour and pressure of the air. You do not set the dew point directly as an input variable.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   June 26, 2018, 07:34
chris
In the first stage, I did as you wrote.
I solve single phase model and look for where the temperature drops below the dew point and velocity has low value. Using the wall model i get another usefull info like condensation mass flux or change in mass fraction.
Thank you for your answer.
Old   June 28, 2018, 07:52
chris
Back to the topic. Vapor-Liquid equilibrium in CFX is defined with Antoin Equation. I calculated vapour pressure for the temp dew point. How can I calculte A,B,C parameters to complete Antoin equation. Thanks for help
Old   June 29, 2018, 16:43
chris
Anybody solved similar problem and can help me? Come on.
Old   June 30, 2018, 06:51
I am not an expert on this stuff, but from my reading of the documentation it is not intended for users to derive the constant terms themselves. You should refer to the literature for the constants for various fluids - the CFX documentation references a textbook which apparently has values for several fluids.
If you want to derive your own constants for a fluid then you better read the literature on how other researchers have done this. This is not a CFX issue.
Old   July 2, 2018, 04:01
Gert-Jan
Gert-Jan will become famous soon enough
The Antoine equations are fit parameters derived from experiments. You will have to look them up in literature. Go to the library and look for one of the heaviest books available:
CRC Handbook of Chemistry and Physics
Gert-Jan is offline   Reply With Quote
condensation, dew point, temperature
[General] How to extract time series data at a specific point location using paraview script Jack001 ParaView 0 April 7, 2016 11:05
Retrieve query point coordonate to create a plane passing through this point. potofus EnSight 2 April 6, 2016 08:26
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 04:44
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 06:11
matching variable data with grid point data anfho OpenFOAM Programming & Development 0 May 6, 2011 16:28
