June 25, 2018, 04:37 |
error in "frozen rotor" interface setting
Jiahui Ming
Dear all,
I'm doing a simulation about the curtis stage of a steam turbine. Here is single passage setting in cfx-pre and it runs successfully. https://www.cfd-online.com/Forums/at...4&d=1529911917 Now I'm attempting to add an injection hole on the first rotor as casing injection simulation. There is a tip clearance on the first rotor, and small volume of steam flow is injected into the tip clearance through the injection hole. https://www.cfd-online.com/Forums/at...5&d=1529911937 My question is the interface setting between tip clearance and injection hole. The clearance domain is rotating while the hole domain is static, so I choose the "frozen rotor" interface,but an error occurs in the cfx solve manager: https://www.cfd-online.com/Forums/at...6&d=1529911954 It's the problem of the interface between tip clearance and injection hole. How could I deal with it in interface setting? Thanks a lot! |
frozen rotor, interface, turbine |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Setting up a standard interface. | Flavio | CFX | 2 | October 27, 2006 13:21 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
