June 12, 2018, 04:12 |
Reynolds No Manually Input
Rupam Das
Is it possible to input Reynolds No Manually in Ansys cfx. After Solution, it is showing some value of Reynolds No. How is it Calculated by Ansys cfx?
Please Help me Out.... |
June 12, 2018, 18:56 |
Rep Power: 144 |
CFX is a dimensional solver. Therefore it uses units of length, time, temperature and not non-dimensional numbers. So if you want to run a defined Reynolds Number you need to define a velocity, length scale and fluid properties which give the Reynolds number you want.
The Reynolds number reported by CFX in the output file by default is an estimate. For the velocity it uses an averaged velocity over the entire field, for a length scale it uses the cube root of the volume of the domain and averaged fluid properties. This will not usually match most definitions of Reynolds Number, such as a pipe Reynolds Number defined by the pipe diameter and average flow velocity on a cross section.
Scaling the Reynolds stresses via UDF | Markus | FLUENT | 1 | November 11, 2022 12:44 |
"Error in subroutine GETCORE": simulation of an turbine and reynolds stress models | nikn | CFX | 8 | October 30, 2019 15:32 |
About the Reynolds Number and Y-plus in external flow | Mason liu | CFX | 18 | November 10, 2014 18:37 |
Reynolds Lenght in SU2.! | Vino | SU2 | 5 | October 27, 2014 04:38 |
Reynolds stresses without velocity correlations? | Phil | Main CFD Forum | 1 | October 2, 2006 04:29 |
