What should i do for (k-e)1E model activating?
Old   April 3, 2004, 13:52
Default What should i do for (k-e)1E model activating?
Michael
What should i do for (k-e)1E model activating? I cannont find anything from documentation.
Old   April 13, 2004, 13:54
Default Re: What should i do for (k-e)1E model activating?
Gloria Gaynor
I think this model is only available on CFX-5.6 and it is not readable under CFX-PRE. Try this:
1. Generate the .def file with k-epsilon turbulence model under CFX-PRE. 2. In a command line inside the cfx launcher (if you´re on windows - on UNIX should be already in your $PATH var) type: <center> cfx5cmds -read -def file.def -text ccl </center>
3. Edit the ccl file 4. Switch the turbulence model from k-epsilon to Eddy Viscosity Transport Equation 5. Now store the new ccl into the def file with: <center> cfx5cmds -write -def file.def -text ccl </center>
You're done.
Enjoy! G. G.
Old   April 14, 2004, 02:45
Michael
Gloria, Thank you very much for help. Your instructions were very helpful. Best regards, Michael
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 16:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 11:27
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
