March 17, 2004, 09:51 |
run Build Topology in IcemCFD 4 CFX
I am working with IcemCFD 4 CFX. When I tried to create the body of my geometry by selecting the surfaces, the program says Error: Please run build topology first There is nothing really helpful in the tutorials of IcemCFD 4 CFX. Anyone know what it is? Thanks in advance. |
March 17, 2004, 13:34 |
Re: run Build Topology in IcemCFD 4 CFX
Ahmed,
Select the Geometry Tab and than Repair Geometry In the Repair geometry menu you will see a magnifying glass with the text "Topology" above it. Select this button and press apply and your topology will be created. When this is done you should be able to create a body I hope I have helped you |
March 17, 2004, 17:19 |
Hi Ahmed and Martijn,
Alternately you could set a material point inside your body and mesh it from there. I prefer using the material point method myself. Glenn |
March 19, 2004, 17:59 |
The problem is, however, that building the topology under Repair Geometry serves a crucial function. It puts explicit curves at the intersections of all faces. The mesh then aligns to these curves.
If you don't use this step, you may see elements that don't quite come all the way to the edges of your geometry. Jeff |
Call for help! Cfx error in Parallel run. | yq11ys | CFX | 5 | November 28, 2022 23:25 |
Build Topology | gridmaster | CFX | 0 | June 6, 2008 19:29 |
How to run CFX on the background? | David | CFX | 1 | January 19, 2004 17:24 |
CFX build | markta | CFX | 1 | October 14, 2002 03:41 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
