May 30, 2018, 01:35 |
Error message
Pedro Oliveira
Rep Power: 8 |
****** Notice ****** |
| The non-dimensional near wall temperature (T+) has been clipped | | for calculation of vap.Wall Heat Transfer Coefficient. | | | | Boundary Condition : JANELA A Side 2 | | T+ clip value = 1.0000E-10 | | | | If this situation persists and you are using the High Speed Model, | | consider enabling Mach number based blending between low speed and | | high speed wall functions. You can do so by specifying a Mach | | number threshold as follows: | | | | EXPERT PARAMETERS: | | highspeed wf mach threshold = 0.1 # default=0.0 (off) | | END I´m trying to simulate multiphase simulation with phase change between water and water vapour with Particle Model. I have already updated the expert parameter but I still go this message, does anyone knows the source of the problem? |
May 30, 2018, 01:57 |
Rep Power: 144 |
You should consider the information the message is saying. It is saying that the temperatures have been clipped. So did your temperature field start to diverge? Or a simulation setup error means the temperature is not controlled properly somewhere? Is it adequately converged? Have you modified the temperature clipping settings?
May 30, 2018, 02:36 |
Pedro Oliveira
Rep Power: 8 |
When I remove turbulence and viscous work from my fluid pair the error message dissapears.
I´m using H20l and H20v as my simulation material, do you think it´s related to the table generation values (max and min temperature and pressure)? |
May 30, 2018, 10:13 |
Gert-Jan
Rep Power: 28 |
The conditions you are modelling are too complicated. Did you consider moderate conditions as a start and then speed things up? That would be a useful approach.
BTW, why on earth should you switch on viscous work? I think this is completely irrelvant. |
June 5, 2024, 10:48 |
TGS
Rep Power: 3 |
I got the same error message and I refined the mesh. It solved the problem.
