cfx boundary condition added by user fortran subroutine doesn't work
Old   May 29, 2018, 07:22
Default cfx boundary condition added by user fortran subroutine doesn't work
leizi is on a distinguished road
Hi everyone, i'm learning cfx user fortran using a very simple steady case: to simulate the flow through a tube. I write a fortran subroutine to supply the outlet back pressure, which is in fact a constant value in the fortran code. I monitored the value from the subroutine and the value of calculated outlet pressure. The subroutine value remains the same during the calculation, but the calculated outlet pressure keeps on dropping to a very low value which is much lower than the subroutine value. How can i fix this?
leizi is offline   Reply With Quote
Old   May 29, 2018, 08:23
Please attach your CCL.
What happens if you set the outlet pressure to the same value in CFX-Pre, so no user fortran?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 29, 2018, 11:24
the function is added like this. It's a simple cel function, reads time step and pressure , returns a constant back pressure value, which is the red line in the monitor. But the calculated outlet pressure(the green line) keeps on dropping as if the back pressure is zero. If i replace the function with the constant value everything is ok.
Old   May 29, 2018, 11:26
if i replace the fortran function with actual value, every thing is ok.
user fortran
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
CFX User Fortran: Particle User Sources hustxinxin CFX 0 March 8, 2012 09:37
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
