May 25, 2018, 15:24 |
Numerical schemes and artificial dissipation
Marcello Asciolla
Rep Power: 8 |
Is there a way to see what is the exact scheme for these options when I choose the numerical scheme in "equation class settings"?
-central difference -high resolution -upwind -specified blend factor Maybe it is in the documentation, but I did not found them. For istance I have an idea for some of them (I know the classical formulation for the "upwind" and the "central difference" ones, but I do not know if there are modified version), but what is the expression used for the "high resolution" or the "blend factor"? Is there a way to use a homemade scheme in CFX? Which scheme can assure the minimum numerical dissipation (I mean the artificial one)? |
May 25, 2018, 17:15 |
Rep Power: 33 |
Documentation section:
CFX Solver Theory Guide/Discretization and Solution Theory/Numerical Discretization/Discretization of the Governing Equations/Advection Term There is no entry for a User Defined treatment of the advection term. Is there a particular advection scheme you would like to try? It would be great to know what such scheme advantage is? |
May 25, 2018, 22:54 |
Marcello Asciolla
Rep Power: 8 |
Thank you, I will try to give a look there.
There is not a particular numerical scheme that I wanted to use, I wanted to know if there is this opportunity. I need a CFD simulation with the requirement of little dissipation because it is for aeroacoustic purpose. |
May 26, 2018, 04:51 |
Rep Power: 144 |
Then have a look at the central difference scheme. CFX also has a variant of central difference scheme for LES modelling - read the documentation for details.
May 26, 2018, 06:05 |
Marcello Asciolla
Rep Power: 8 |
Yes, I was thinking about a central difference one. I do not know if there is anything better than it, for this reason I also asked for a suggestion about different schemes... And I am glad to hear that there is a different version for LES, so I must think that they already thought about that.
May 26, 2018, 07:00 |
Rep Power: 144 |
Low dissipation is essential for LES, so you have a few low or no dissipation options for LES models.
cfx, equation, scheme |
Melt front artificial dissipation with VoF | steph79 | FLUENT | 0 | February 22, 2016 08:13 |
Artificial dissipation for NS equations, flow in a pipe | RameshK | Main CFD Forum | 8 | November 13, 2011 11:29 |
numerical scheme without artificial diffusion artifact | mpeti | OpenFOAM Running, Solving & CFD | 2 | October 26, 2011 12:36 |
Two questions on Numerical schemes for NS equations | RameshK | Main CFD Forum | 0 | December 21, 2010 08:46 |
Standard for checking and testing numerical schemes? | X. Ye | Main CFD Forum | 7 | August 31, 1999 18:05 |
