May 24, 2018, 10:10 |
Does mesh refinement affect solver?
Young Gun Lee
I was trying to simulate fluid flow through a channel with different size of mesh.
I've tried 80k, 104k, 174k, 192.5k, and 260k no. of mesh. They all converges well, but when I try 240k mesh, error occurs during solver. I'm sure that same boundary conditions were applied. |
May 24, 2018, 19:29 |
Rep Power: 144 |
The numerical scheme in CFX is dissipative (just as for all solvers I know of). When you run a coarse mesh the numerical scheme adds dissipation which helps stabilise the convergence. As you refine the mesh the dissipation reduces and there comes a point when the stability is not adequate to converge. This is normal CFD solver behaviour.
If you find you need the fine mesh solution you will probably have to run transient to get it to converge.
convergence, mesh, solver |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 20:34 |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 06:39 |
[snappyHexMesh] sHM refinement away from surface | nholt | OpenFOAM Meshing & Mesh Conversion | 1 | June 14, 2016 15:36 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 14:28 |
[snappyHexMesh] Propeller mesh not smooth | nortanapura | OpenFOAM Meshing & Mesh Conversion | 0 | May 16, 2014 04:26 |
