Problem with an Axial Pump Impeller Mesh / Geometry - ANSYS CFX |
May 15, 2018, 13:40 |
David Valladares
Rep Power: 13 |
Hi everyone. I have a medium level of experience in ANSYS CFX. My problem is with the geometry or the mesh.
I´m working with an axial flow pump impeller and diffuser. I imported the geometry from Autodesk Inventor and prepared in ANSYS Design Modeler. After that I meshed in ANSYS TurboGrid, no errors reported. When I opened the CFX Pre there is a chamfer or a cone at the diffuser´s outlet, I came back and reviewed all the process and everythings seems to be ok, I have no idea of what´s going on with the mesh or the geometry. Have you any idea of why is that happening? Thanks for your time! David |
May 15, 2018, 19:30 |
Rep Power: 144 |
Can you post an image which clearly shows the chamfered edge you are talking about?
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Problem on mesh import to Ansys CFX 10.0 | Stephen Lau | CFX | 1 | April 18, 2007 04:02 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
