May 15, 2018, 05:00 |
Validation.
Mohan Kumar Dey
Rep Power: 9 |
Is my validation is acceptable if I carry out my validation with correlation? Example, like I got pressure drop results from simulation then I compared these results with the Kern pressure drop correlation formula.
If I carried out Kern pressure drop correlation formula by analytically and compare with the simulation results, Is it okay? please give me some suggestions...... |
May 15, 2018, 19:28 |
Rep Power: 144 |
Then your results are as good as the Kern pressure drop correlation. Correlations vary from highly accurate to terrible so you will have to determine what this means in your case.
Validation in Transient tasks | MaxakCh | FLUENT | 0 | May 17, 2013 09:59 |
CFX problem in ubuntu (linux) | Vigneshramaero | CFX | 0 | July 13, 2012 11:22 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 01:52 |
Validation test for 2d euler equations in subsonic regime with canonical squares | panou | Main CFD Forum | 2 | August 24, 2011 16:21 |
Urgent: RAE 2822 validation | NID | Main CFD Forum | 0 | September 3, 2004 11:34 |
