May 14, 2018, 17:58 |
"if" expression problem
Kim Gunhyeong
Rep Power: 8 |
Hey guys. I have problem in "if" expression.
I try to design butterfly valve model, so I make spherical shape domain which has vavle shape empty space in. Then I give rotation speed to that domain, using expression; if(ctstep<150[ ], 1.046[radian s^-1], 0) but CFX error checker doesnt permit it. Whats problem? Plz help me |
May 14, 2018, 18:18 |
Rep Power: 144 |
Try:
if(ctstep<150, 1.046[radian s^-1], 0[radian s^-1])
May 15, 2018, 00:54 |
urosgrivc
Rep Power: 11 |
ok, so the units are not ok,
but i think that the problem is in your simulation. It might be the problem vith interfaces (sfere) have you split the surface or vhat does the conection look like And you can plot your expresion, and use that, because it is great for troubleshoting it would give you an erorr if you would try to plot it before you run the solution. Last edited by urosgrivc; May 15, 2018 at 03:31. |
May 15, 2018, 09:55 |
hmm.....
Kim Gunhyeong
Rep Power: 8 |
Thanks ghorrocks. I do as you recommend, so unit problem disappear But CFX doesn't recognize "ctstep".(I find this expression at CFX post-processing - Current Time Step ) Is it wrong usage? Plz help me. |
May 15, 2018, 12:32 |
urosgrivc
Rep Power: 11 |
Use:
Acumulated time step it is in the wariables |
May 15, 2018, 17:36 |
Erik
Rep Power: 23 |
Why not just use the real variable time "t" instead of time step?
condition, ctstep, expression |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 04:28 |
Define an Expression in Pre with another User Defined Expression and a Variable | fuGGet321 | CFX | 6 | May 8, 2018 16:19 |
Large problem partitioner | tzy | CFX | 3 | February 7, 2018 17:11 |
Modify SST kw model in CFX | Tingyun YIN | CFX | 6 | May 12, 2017 06:44 |
CCL / Monitor Object Problem | James Date | CFX | 4 | September 29, 2010 02:23 |
