Isolated volume error
Old   May 13, 2018, 14:26
Post Isolated volume error
Julian121 is on a distinguished road
As I said in my previous post, I am simulating a type of vane recessed casing treatment.
I used solidworks to design the casing treatment and the vanes. Then, I used design modeler and used boolean function to create flow domain around the vanes.
The vane have been selected as solid and the rest of domain have been selected as fluid.
I used meshing to create mesh around the vane with default setting.
As soon as the simulation starts, the isolated region error appears and the simulation stops.
The isolated volumes in cfd-post shows that there exist two isolated volumes on both sides of the vanes.
I have defined an interface between the casing treatment and the shroud in addition to define wall boundary for all sides of the vane and casing treatment.
My question is: should I define any other interface to fix the problem?
Julian121 is offline   Reply With Quote
Old   May 13, 2018, 20:07
I do not understand what that image shows.
The isolated volumes error simply means you have a domain which is unconnected to the other domains. If they were intended to be connected, then the error says you missed an interface.
Also - are you modelling the vanes? Or are the vanes not modelled and exist as cut-outs in the fluid domain? You should only model the vanes if you intend to do heat transfer modelling on them.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
