Transient flow FSI
Old   May 11, 2018, 01:59
Default Transient flow FSI
Rohan V. Kedare
kedarerohan is on a distinguished road
I am trying to simulate vibration in pipe due to flow. Simulation metod used is coupled analysis of transient structural & transient flow analysis.
But this analysis is consuming huge amount of space. In my case hard disc space required is >400 GB.
Is there any other way to reduce this simulation space?
kedarerohan is offline   Reply With Quote
Old   May 11, 2018, 09:46
Opaque will become famous soon enough
How is the disk space being used? For transient files?
What kind of information do you require in the transient files? All of it, or just certain variables. For the latter, you should use Selected Variables.
Do you need the information for the whole volume? or just the boundaries?
Opaque is offline   Reply With Quote
Old   May 11, 2018, 23:55
As opaque states you can choose what variables go in the results file if you like. And in recent versions of CFX you can also select only a portion of the mesh or boundaries to be saved as well. So some combination of these will reduce the results file size a lot.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ansys coupled analysis
Transient simulation of flow through a valve aadit.shroff Main CFD Forum 12 April 12, 2018 05:20
FSI Transient Load Mapping (ACT) attiquejavaid08 ANSYS 1 November 10, 2016 03:28
1-way time step problem in doing FSI between Fluent and Transient Structural sihaqqi ANSYS 0 November 21, 2013 03:45
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 03:07
Poor Convergence for Transient Subsonic Diffuser sims with flow separation TWaung CFX 1 April 16, 2009 09:25
