Heat Transfer Coefficient contour
Old   May 10, 2018, 20:17
Smile Heat Transfer Coefficient contour
Azrul Sapawi
Azrul Sapawi is on a distinguished road
Can someone tell me how to create the contour for Heat Transfer Coefficient in CFX. I get the value but the contour only show the constant color not like other parameter.
Thanks you
Azrul Sapawi is offline   Reply With Quote
Old   May 11, 2018, 01:56
HTC only exists on wall boundary faces. The only place you will be able to show contours of it is if you show it on a wall boundary face. If you show contours of HTC in the volume mesh it will just show zero everywhere.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Heat flux and Heat transfer coefficient sakil2k3 FLUENT 4 July 5, 2015 16:07
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 16:35
negative heat transfer coefficient in contour sharad_kumar101 Main CFD Forum 1 April 21, 2010 10:58
