Fitting casing treatment on rotor
Old   May 10, 2018, 11:51
Unhappy Fitting casing treatment on rotor
Julian121 is on a distinguished road
I am using bladegen to design a rotor blade row where a type of casing treatment will be attached to the rotor (image 1). I used straight lines to define the space required to attach casing treatment later. However, when I import the geometry to turbogrid or ICEM, the straight lines become curved (image 2), so the casing treatment does not fit the space perfectly. Any idea what I should do to keep their shapes as shown in bladegen? Thanks!
Julian121 is offline   Reply With Quote
Old   May 11, 2018, 08:21
Post
I forgot to upload a screenshot from CFX-Pre. Due to the change of shroud curve a gap arises between the casing treatment and the rotor.
Does it affect the result?
Originally Posted by Julian121 View Post
The simulation of a centrifugal compressor with holed casing treatment gongmq CFX 4 July 16, 2018 06:15
Interfaces between blade channel and casing treatment SNeCu CFX 3 September 20, 2017 23:36
Add casing treatment in NUMECA SNeCu Fidelity CFD 9 July 25, 2017 00:15
Rotor Torque Prediction jason OpenFOAM Running, Solving & CFD 7 August 16, 2016 10:34
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
