Modeling of vacuum evaporator
Old   May 7, 2018, 06:45
Post Modeling of vacuum evaporator
Behrooz Jamshidi
CFD-fellow is on a distinguished road
Hi
One method of chilling water is to put it under high vacuum so that the liquid reaches its saturation pressure.The water starts boiling and the vapor gets latent heat of vaporization from remaining water. This causes the water to get cold. For example water enters the evaporator at 12 C and exits at 6 C.
Is it possible to model this process in CFX? Which multi phase model should I use?
*Its enough to model evaporator with just two phases (water and water vapor without air)
CFD-fellow is offline   Reply With Quote
Old   May 7, 2018, 14:25
Gert-Jan
Gert-Jan will become famous soon enough
Yes this is possible. You could use a so-called material H2Ovl (vapour-liquid system) which assumes local equilibrium conditions (i.e. inifinite mass transfer rate).
Multiphase system is a bit more difficult. It depends on where boiling starts.....
But, what question do you want to answer using CFD? In other words, what challenges do you encounter?
Gert-Jan is offline   Reply With Quote
modeling of vacuum Mukund FLUENT 1 April 15, 2020 09:21
Modeling a vacuum region in solar collector with fluent amirokhovat FLUENT 2 November 4, 2016 07:36
radiation modeling in vacuum mirko OpenFOAM Programming & Development 7 May 20, 2016 09:31
Modeling gas expansion in vacuum cryonole FLUENT 2 August 21, 2014 11:19
Modeling sudden flow in Vacuum chamber Sandilya Garimella FLUENT 0 February 8, 2008 16:04
