Fantom element
Old   February 14, 2004, 22:46
Default Fantom element
Bob
Good day to everyone!
At the very beginning of solving in CFX 5.6, it generated the message (cited below) referring to the zero-volume element. BUT! 1)There nothing at all in the model at those coordinates. 2)The HEX element of the referred No. is 15 mm apart from the referred coords. and it is perfectly OK. Anybody would know what does it mean and how to fix?
Thank you
Bob
ERROR #002100010 has occurred in subroutine cVolSec. One of the sector volumes of an element is equal to or less than zero. It means that there exists an illegal mesh, execution will be stopped immediately. The element sequential number is: 4 The element label is: 4 The sector volume is: -0.2777E-11 The location (x,y,z): 0.32849E-02 0.72707E-02 0.31768E-01 |
Old   February 15, 2004, 17:53
Default Re: Fantom element
Hi Bob,
Are you using moving mesh? This is a common error with moving mesh simulations.
Glenn
Old   February 16, 2004, 00:31
Bob
Hi, Glenn, thanks for your quick response!
Yes, this is a rotating ref.frame (the default one). (The inlet BC is stationary, with radius-depended theta-component of inlet velocity.)
Old   February 16, 2004, 01:03
deLuther
I got such error when I worked with mesh imported from ICEM CFD(double precision output file produced same result). I only solved that problem by correcting the mesh(in ICEM everything was OK). (my application is turbomachinery)
Old   February 16, 2004, 17:24
Hi Bob and deLuther,
Bob, the feature I was referring to is the moving mesh feature where you can specify arbitrary mesh motions. You mention you are using multiple frames of reference, which is a different thing.
deLuther, what did you find was actually the problem? What did you do to your mesh to fix it?
Regards, Glenn
Old   February 17, 2004, 01:04
deLuther
Hi, Glen, I fixed my mesh by correcting mesh sizes and angles, which has been corrected by moving vertices of blocks. But initial mesh was OK in ICEM, but don`t loaded well in CFX-Pre. Problem was in relatively thin elements coupled with relatively sharp angles.
Regards, deLuther
[Gmsh] gmshToFoam unhandled element flowris OpenFOAM Meshing & Mesh Conversion 4 February 20, 2023 18:50
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 05:35
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 18:57
[Gmsh] Gmsh and element size factor msarkar OpenFOAM Meshing & Mesh Conversion 0 May 2, 2011 03:55
