thermal phase change question
Old   February 14, 2004, 06:36
Default thermal phase change question
CFDflying
Hi,all friends. I try to model a thermal phase change project. Some subcooling water is injected into the pipe and meet the hot gas(c3h8) in the pipe. A part of water is boiling to be vapour. I try to model it with cfx5.6, but when I select the thermal phase change, the solver will overflow. I have check the transient result, all the water is evaporated, even near the water inlet. It is not reasonable. And I make a test model there is only water and vapour, the result is same.
I have no idea about it. Could you give some advice? Or send me a simple example about thermal phase change model. Thanks.
Old   February 18, 2004, 05:10
Default Re: thermal phase change question
Andrey
I have same task. Water injected into column for cooling hot humid air. I use multicomponent (humid air = air + vapour) multiphase (humid air + water) simulation. The mass evaporated water I define with CEL expressions and use SUBDOMAIN to set mass and energy source and sink.
simulation of phase change material melting rosol FLUENT 4 December 8, 2015 08:56
Instability in phase change computations quicksilver Main CFD Forum 5 June 6, 2009 11:25
How to model the solid-fluid phase change in CFX ohrmond CFX 2 May 26, 2006 07:27
Phase change process Sang-jin Lee Siemens 5 December 5, 2001 06:17
Phase change modelling Sebastien DANIEL FLUENT 1 July 6, 2000 04:35
