CFX 5.6 mesh build
Old   February 13, 2004, 02:39
Default CFX 5.6 mesh build
shhe
Hello users
I am a new usre for CFX 5.6. I have worked for two years with CFX 4.4. I have problem in rotating object in mesh build. I have known that in CFX 4.4 I have to create groups and tanslate or rotate this group about pivoting point with any degree. I want to know how can I make these procedure in CFX 5.6. Foe example, I want to create a tilted pipe. I have created a cyclinder surface from two curves. How can I rotate this surface?
best regards
Old   February 13, 2004, 05:27
Default Re: CFX 5.6 mesh build
test
hi,
You can import your mesh in Pre and transform the mesh as you wish. Go through the help manuals which should explain to you as to how you can do this. Search for emsh transformation in the help section
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! Vu Trinh Tuan CFX 11 March 28, 2005 20:04
CFX build 5.6 Richard CFX 8 September 10, 2003 13:20
