additional variable mass transfer in CFX5.6
Old   February 8, 2004, 22:40
Default additional variable mass transfer in CFX5.6
john
Hi, All
I have one question about setting additional variable mass transfer in CFX5.6. Hope to get your help as soon as possible.
This is a two phase (gas and water) problem. There is a soluble component (A) in gas phase. I want to model the mass transfer of A from gas to water. I set two additional variables for A in each phase and try to set mass transfer of the additional variable pair in fluid pair panel.
My question is: it looks like there is only ¡®additional variable transfer coefficient¡¯ option in that panel. I did not find other options for inputting total source of mass transfer or mass transfer flux.
Assuming: source=density*interphase transfer coefficient *(saturation mass fraction of A in water- actual mass fraction of A in water), in which saturation mass fraction of A in water can be calculated by Herry's law. How can I input this source term in CFX-pre?
Thanks!
John
Old   February 14, 2004, 01:30
Default Re: additional variable mass transfer in CFX5.6
Jeff
Put a source term into the AV equation, equal and opposite in both phases. Calculate the volumetric source of your AV in CEL as per your equation and enter the source term as a CEL variable.
Jeff
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 26, 2011 00:26
How to get mass transfer coefficient in FLuent? bigfans FLUENT 4 May 9, 2009 21:03
Multi_component Vs Additional Variable Anurag CFX 2 February 4, 2005 17:45
