May 3, 2018, 11:49 |
Moving Heat Source on CFX
Constantinos
Rep Power: 8 |
Hello!
I am trying to simulate friction stir welding on CFX and I wish to create a moving heat source. On COMSOL Multiphysics that was achieved by applying a translational motion with steady velocity (along x-axis) to the heat transfer. Is there a similar way to do so? I have also thought that instead of applying velocity u on the heat source, to apply velocity -u on the coordinate system. Is it possible to create a moving coordinate system on ANSYS CFX? Or in general, how can one create a moving heat source on ANSYS CFX, in terms of a heat flux having a translational motion? Last edited by nagas; May 3, 2018 at 11:50. Reason: add tags |
May 3, 2018, 15:03 |
Rep Power: 33 |
You can model it as a heat source moving, or a transient fixed (space) heat source
Write a CEL expression for heat source as a function of time along the boundary. Such expression should include the speed of the moving source and time to determine the location, as well as the strength of the source. |
friction stir welding, moving coordinate system, moving heat source |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Coupling a chemical reaction with a heat source in CFX | JohnPuentes | CFX | 0 | July 14, 2014 05:27 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
