Error in CFX Solver
Old   May 2, 2018, 23:40
Default Error in CFX Solver
Pedro Oliveira
oliveira1820 is on a distinguished road
Hello to everyone,
When I start the solver of my transient CFX fluid simulation I get this messagage at the first coefficient loop :
GETCORE stacktrace
1 Post_soln, ,CVVOL,ZN1/VERTICES,LATEST
Does anybody knows how to solve this problem or to what is related?
Thanks
oliveira1820 is offline   Reply With Quote
Old   May 3, 2018, 02:39
Gert-Jan
Gert-Jan will become famous soon enough
We more info than that. Can you provide the last part of your output file so we are able to see what is happening?
Gert-Jan is offline   Reply With Quote
Old   May 3, 2018, 03:57
Pedro Oliveira
I´m sorry, I´m new at this software and can´t find the output file anywhere. In the Post folder there isn´t any file, here can I find it?
Old   May 3, 2018, 04:14
M
AtoHM is on a distinguished road
There should be a text file with <name of your simulation>.out
Thats the output file, which is also shown in CFX Solver Manager when monitoring the run. Depending on your calculation (serial or parallel) and if you run it locally or at a cluster or something, it can be placed at different places. Check if there is a standard working directory or something, it might be there. Or try windows search for *.out anywhere close to where you think it should be.
AtoHM is offline   Reply With Quote
Old   May 3, 2018, 08:52
Pedro Oliveira
OUT FILE.txt
Found it, here it is
Old   May 3, 2018, 10:19
M
Actually I was hoping for a clearer error message, this is actually not very useful. However, I noticed you have highly skewed elements in the mesh statistics part, with your minimum angle at about 5 degree. As far as I remember from the manual, you should at least have 10 degree, everything upwards is favorable of course. I would start with improving mesh quality.
Old   May 3, 2018, 15:16
Opaque will become famous soon enough
Not a trivial error to diagnose. Some calculation failed while getting ready to write the first transient file
Try removing the transient file output first, and see if you can run say 5 timesteps to see if the final results files can be written.
Otherwise, try contacting ANSYS CFX support and provide your definition file.
Opaque is offline   Reply With Quote
Old   May 3, 2018, 17:36
Gert-Jan
Hi Pedro,
You mentioned you are new to the software, but the case that you setup looks pretty complex (H2Ovl-system, total energy, etc). That does not really match. What are you trying to solve?
Regs, Gert-Jan
Old   May 10, 2018, 03:06
Pedro Oliveira
Hi guys, I tried improve my mesh but keep getting the same error:
"GETCORE stacktrace
1 Post_soln, ,CVVOL,ZN1/VERTICES,LATEST"
Do you know how can I improve the mesh and raise the minimum angle?
Old   May 10, 2018, 03:07
Pedro Oliveira
Gert-Jan, I´m working with a thermodynamic nuclear target simulation with cooling water system and studiyng the condesation/vaporization of the water inside too.
Old   May 10, 2018, 03:41
Pedro Oliveira
Opaque, I removed the transient file and it calculated the solutions for 5 iterations, but then the solving stopped again and the same error appeared.
Old   May 10, 2018, 08:49
Gert-Jan
My advice is to go back to basics. You are new to the software but are trying to include all physics from the start. That is asking for failure. Even I never do that.
So take your mesh and start as simple as you can imagine. And see of that works.
Step 1: do a simple simulation with water flowing through your domain. Does that work?
Step 2: Add sim ple heat transfer.Does that work?
Step 3: Add source terms and viscous heat (Do you really need that?)
Step 4: Add multiphase.
Step 5: Make it transient
Then you will bump into the error and may find the cause.
BTW, You have a very small license and you are focussing on modelling physics. Not a windmill or a solar car with Cw=0.1 where mesh is very important. So forget the mesh. CFX can handle very bad mesh. First get the physics right and then at second thought look to the mesh.
CFX Solver Manager Error Code 1 Peta247 CFX 3 June 4, 2016 12:00
The ANSYS CFX solver exited with return code 1. No results file has been created moodkiller CFX 7 May 23, 2016 03:16
CFX solver workspace & ourfile Problem wangy1767 CFX 1 January 9, 2013 10:38
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 17:42
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 23:54
