April 30, 2018, 13:08 |
periodic
Hosam
Rep Power: 8 |
I'm working in nuclear reactor sub-channel analysis in Ansys CFX , and i want to simulate heat transfer and flow of coolant, and some of my difficulties is how to make periodic boundary, and another one is how to simulate solid domain inside fluid domain?
April 30, 2018, 15:14 |
Erik
Rep Power: 23 |
Periodic flow only? Or flow and heat transfer? The latter can get difficult with CFX.
If flow only, you would use a translational periodic interface between your inlet and outlet. It is best to have a 1:1 mesh at these two locations. Tutorials show several examples of this. Simulating heat transfer between solid and liquid domains is standard, there are many examples in the tutorials. You just use a domain interface between the two domains. |
May 2, 2018, 08:35 |
replay
Hosam
Rep Power: 8 |
=evcelica;690800
in reactor sub channel periodic.is rotational between horizontal sides and vertical side, and heat tansfer between fluid and mixing vane |
3D Periodic Boundary in SU2 | jywang | SU2 | 1 | May 1, 2018 21:43 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 12:25 |
[ICEM] Periodic condition between ICEM and FLUENT | Touré | ANSYS Meshing & Geometry | 0 | August 5, 2012 18:00 |
HELP! Periodic Problem | foxer | FLUENT | 1 | June 27, 2012 09:00 |
[ICEM] how to define periodic in icem ? | mingersai | ANSYS Meshing & Geometry | 1 | February 3, 2012 18:46 |
