April 24, 2018, 18:08 |
A wall has been placed at OUTLET
Ali
Rep Power: 10 |
I am simulating a brush seal. I have extended my inlet and outlet. But I get this error message : A wall has been placed at portion(s) of an OUTLET It is 30% of the face. One guy told me if you change it to opening, you will get more problems. So could anyone please explain me, what will be the problems by changing the outlet to opening ? I thank you in advance |
April 25, 2018, 03:08 |
Gert-Jan
Rep Power: 28 |
Why don't you give it a try and see what you get?
When an outlet has a wall, this wall is artifical and will prevent fluid to enter through the outlet. When changing to an opening, no artificial wall will be placed, so the fluid will enter through your opening. Then you need to define what is entering (T, concentrations, etc) and in what direction (usually normal direction). The question is whether these boundary conditions are realisatic. It might be better to move your outlet further downstream........ BTW, it is a FAQ: https://www.cfd-online.com/Wiki/Ansy...f_an_OUTLET.22 |
Inlet and outlet boudary without wall between | Janshi | CFX | 5 | February 2, 2012 04:51 |
A wall has been placed at portion(s) of an OUTLET | aero123 | CFX | 1 | November 9, 2011 18:14 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
solution problem : A wall has been placed at portion(s) of an OUTLET | alnabhani | CFX | 1 | August 8, 2010 18:46 |
Combining BCs: wall - outlet. Boundary layer disappears | MartinaF | OpenFOAM Running, Solving & CFD | 1 | July 20, 2009 18:14 |
