Hi, I am trying to solve a simple 2d solidification problem in a rectangular domain. There is no inlet or outlet, it is a closed domain. Top and bottom walls are adiabatic. Rihght side boundary is cooler than solidus temperature. Left side boundary is hotter than liquidus temperature. I am trying to find out a transient solution. After 3 iterations I am getting a furious solution in which the minimum temperature falls below the cool wall. I have tried reducing the time step and using underrelaxation factor for conservative mass fraction, it didn't work. Can any one kindly help me?? Thanks in advance. Regards, balu.
problem in modeling fluid-solid-fliud | reem | FLUENT | 12 | June 10, 2018 05:37 |
Regarding Solidification modeling | Anil Samale | FLUENT | 1 | May 29, 2008 10:18 |
modeling of coupled problem | Godfrey | FLUENT | 4 | May 22, 2002 14:52 |
continue the problem with RSM modeling | cwflying | FLUENT | 3 | April 28, 2002 07:48 |
problem with RSM modeling | cwflying | FLUENT | 4 | April 18, 2002 06:45 |
