Ambient Temperature as Function in Thermal Transient (Mechanical)? |
April 22, 2018, 18:44 |
Dêivide Álisson Winter
Rep Power: 8 |
Hi, everyone.
I am using Ansys Workbench 18.2, more specifically the Transient Thermal. I have a convection in which the Ambient Temperature needs to be a function that will depend on a variable that I'll call "Temperatute_Furnace". But how and where do I define this variable? How can I do to this variable to change according to a equation during the simulation? Should I use Commands (APDL)? (if positive, how do I do it?) I know I am quite lost, but I googled a lot and I didn't find neither the answer or a similar example. Image of the screen in which I am working on: https://uploaddeimagens.com.br/imagens/convection-png Thanks. |
April 22, 2018, 19:21 |
Rep Power: 144 |
Transient Thermal in workbench uses ANSYS as the solver. This is the CFX forum.
But in ANSYS you can define variables as equations. I did it a while ago but I cannot recall the details. I worked it out from the documentation, so have a look at the ANSYS documentation and you should be able to work it out.
April 22, 2018, 19:43 |
Rep Power: 8 |
Thank you for your reply.
I'll repost it on ANSYS forum, but I didn't find how to erase this post. |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 12:32 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 23:07 |
Failed to transfer temperature data from Transient Thermal to Transient Structural | wzhmanu | ANSYS | 0 | August 17, 2016 21:16 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
Thermal conductivity as function of temperature | magazoni | OpenFOAM Programming & Development | 5 | May 19, 2016 19:25 |
