How to apply mesh deformation only to a edge? |
sluzzer
Rep Power: 12 ![]() |
For example, take a variable area nozzle, in which only the exit diameter opens up.
In this case, we want to apply radial motion only to the edge of exit diameter. But, cfx allows mesh deformation setup only to the surfaces. Is there a way by which we can move only the edge ? Thanks. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
You can make mesh motion a function of position so you can do complicated motions. But I suspect you don't want to do that, if you posted an image of what you want to do I suspect there will be a simple way of doing it.
sluzzer
It's like a variable area exhaust nozzle of a jet engine.
Geometry is like a truncated cone. The smaller diameter of the truncated increases over time. I will post the image soon. Thanks :-) |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Mesh deformation memory requirements | aa.g | SU2 | 5 | March 24, 2020 15:34 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
