Rep Power: 15 ![]() |
I am simulating flow in an axial flow compressor near choking point.
There is a bellmouth at the inlet of compressor as shown. I have two questions: 1. Can the bellmouth be added to the rotor domain in the bladegen? I saw it in a tutorial (axial fan) that the intake was included in the domain of rotor. I am using solidwork to draw a section of intake and then use a general interface to connect the bellmouth and the rotor. 2. When I simulate near the choking point, the residual history shows that the momentum components go up and down and the solution never converges. Does this occur because of wrong BC? I am using static pressure bc at the outlet. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
1. Yes, it can rotate. Make the walls counter rotating if they are stationary.
2. FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
Does a big axial gap between the bellmouth and the first blade row which might happen in a static test rig justify ignoring its influence on downstream components? Besides performance map, what can be used to measure its influence and justify ignoring its effects?
#4 | ||
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
In the case of convergence | aja1345 | FLUENT | 1 | July 31, 2015 03:58 |
CFX overwhelming Fluent in mass convergence of boundary layer separation case | Pierre1 | FLUENT | 7 | March 26, 2015 21:43 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
