Failure in partitioning due to axial fluid-solid interfaces with frozen rotor model
Old   April 18, 2018, 09:46
Question Failure in partitioning due to axial fluid-solid interfaces with frozen rotor model
Fred_Erik is on a distinguished road
Dear all,
I have a problem with interfaces between fluid and solid domains. Some domains have rotational periodicity. So the connecting surfaces have a pitch change. For this I selected the frozen rotor interface model with specified pitch angles. The surfaces contain radial as well as axial surface parts. I separated them in one interface with pure axial faces and one interface with radial faces as it is recommended in ANSYS CFX Help. When I start the solving job the solver stops in partitioning part with failure in transformation of cylindrical coordinates of the interface with only these axial sections. The problematic axial surfaces are only on the side of the fluid domain. I have no explanation for this. Did I forget something in my settings? Can anybody help or has some advice? Thank you!
Fred_Erik is offline   Reply With Quote
Old   April 18, 2018, 21:09
Can you attach an image of what you are modelling?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   April 19, 2018, 05:59
Post
Hello ghorrocks,
I attached an image which shows an extract of the problematic geometry. The pitch change is quite large, but this shouldn't be a problem, because it is full rotational periodic in fluid domain, isn't it? I tried it with pitch ratio of 1 in some other area, but it fails, too. The problem apperars if I choose the frozen rotor model.
What about meshing? The mesh in the fluid domain is fine with using prisms for the boundary layer. The mesh of the solid domain is coarser and has no prisms. Are there important recommandations concerning meshing?
Thanks for an answer!
Old   April 19, 2018, 08:52
Your fluid domain appears to be only 0.2 degree segment. An angle this small is going to cause problems as the mesh quality will be terrible and getting the GGI interfaces to match up will also be difficult. Try a larger segment angle, 2 to 5 degrees would be my recommendation.
fluid-solid, frozen, interface, partitioning, rotor
Theory behind the solid domain rotation in fluid using Bets property Riken CFX 0 October 28, 2009 10:51
Interfaces 2D - How to build between fluid and solid (fin)? rogbrito CFX 0 July 13, 2009 22:13
modelin fluid and highly flexible solid interfaces matt r. Main CFD Forum 2 August 17, 2005 09:57
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
