Porous Media
Old   January 12, 2004, 11:58
Default Porous Media
Christian Cordeiro
Hi, I am working with CFX 5.6 and I want to simulate a bank of tubes using Porus Media and I have some questions about Porous Media x CFX: 1- Is necessary create a subdomain to define a region with Porous Media ? 2- If yes, Which Boundary Type do I must set (in,out,wall..) ? 3- How can I calculate the Porous coefficients in the CFX (I didnīt find sufficient informations) ?
Thank you
Old   January 13, 2004, 04:56
Default Re: Porous Media
Forrest
Hi, Christian
There are some comments about porous media in CFX community site which might be helpful.
http://www-waterloo.ansys.com/cfxcom...a_in_CFX-5.htm
You probably need to set up a subdomain(s) to specify the resistances.
Regards Forrest
Old   January 16, 2004, 19:57
Jeff
Christian,
Yes, you need a subdomain to apply the resistances. CFX-Pre will only give you a source term panel if a subdomain is defined for your porous media.
My personal thoughts on walls within a porous region, are that the pressure drop is pretty much accounted for by the resistance factors you are setting. Any additional boundary layer effects near the wall are either a) much smaller than the resistance effects or b) already included in your resistance factor. It doesn't seem right to let the code develop a wall profile, when in actuality the porous media would break this up anyway.
For resistances through all kinds of porous media (screens, tubes, plates), look in references by Idelchek and/or Blevins.
Jeff
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
species mass source in porous media ? PK FLUENT 0 February 16, 2007 12:12
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
