January 12, 2004, 10:35 |
starting with dump file
I am having trouble strating a run from a dump file. I have the error:
:>MODEL BOUNDARY CONDITIONS ERROR OPENING RESTART FILE ON UNIT NUMBER 16 THE CFX-4 SOLVER HAS BEEN STOPPED BY SUBROUTINE OPENIO Anyone got any hints? Also, how does the solver "look" for the correct dump file (does it need an appropriate name, and if not how are files prioritised)? Lastly if I want to set initial variables and read in variables from the dump file, will these conflict? Many thanks in advance Dougal McQueen |
January 14, 2004, 07:42 |
Re: starting with dump file
In case anyone else out there gets this error. It was caused by the solver not "finding" the dump file, no matter what I named it. You can point the solver to the dump file on the command line using -r e.g. runsolve4 -c m01.f -f aaa.f bbb.f -r dump_file.dmp
Does anyone know where references to command line instruction can be found? Thanks Dougal |
January 14, 2004, 17:32 |
Hi
Been a while since is used CFX-4.4 but i think you need to make sure the .fc and .dmp restart files have the same number. Another thing, whats the point restarting from a dump file and also specifing intial field variables? The restart data will just be over written! This is just like starting a fresh run. Regard James |
January 15, 2004, 05:03 |
I am using the dump file as the initial condition for most variables (u, tke, e etc..), but have scalars added in the second run.
Many thanks Dougal |
January 16, 2004, 20:03 |
For command line parameters use "runsolve4 -h".
You can also look in the top of your .fo file when running from the environment to see what command line command was used to create the run. Your SET INITIAL GUESS values will overwrite anything that's read in from the dump file. Useful for re-initializing a scalar field but not the flow solution. Jeff |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 18:33 |
gcc and executable file from Mac to Linux | simone Marras | Main CFD Forum | 0 | April 8, 2007 16:49 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
