Defining coordinate system using parameters in CFX-Pre |
Michael
Rep Power: 9 ![]() |
I am trying to run my simulation in a rotating reference frame. I want the reference frame to be offset from the global coordinate system in the global x-y frame. When I add a coordinate system I can only enter numerical values into the defining points. Is there a way to add this using parameters? Thanks |
Gert-Jan
Rep Power: 27 ![]() |
Yes, this is possible. For example, you can create three expressions. Lets say a,b &c
a=1[m] b=1[m] c=a+b Then, in Pre, right click on your coordinate frame and select "Edit in Command Editor". This opens the definition of your coordinate frame in text format. Now you can replace numbers with your expressions a,b&c Make sure that your expressions always have the dimension [m]. |
Michael
Thanks! That solved the issue.
cfx pre, coordinate system, parameters |
Define a cylindrical Coordinate System in CFX!!! | mohammad | CFX | 0 | September 10, 2014 02:27 |
Defining local coordinate system | bastil | OpenFOAM Pre-Processing | 11 | August 8, 2011 08:26 |
Creating Coordinate System | ashtonJ | CFX | 0 | February 17, 2011 21:07 |
CFX 5.7 pre | Neser | CFX | 0 | January 27, 2005 11:22 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
