April 20, 2018, 07:06 |
#21 | |
naman doshi
Rep Power: 9 |
as i am giving a constant source terms (5kg/hr of water vapour) which is being added till some steady state is reached thats why mass fraction is going so high, while in real scenario as humidity in air would increase, rate of evaporation would eventually decrease hence i need to define a udf based on humidity level such that source term vanishes after reaching the condition required. while in case of water vapour@25'c temp is going so high so as to accommodate water vapour in air as temp of air increases its capacity to hold water vapour increases. Sir can you please help me to define udf for water vapour(based on surrounding or incoming moist air inside cooler from back of cooler) and an energy source (based on surrounding temp. and amount of water evaporated) source of energy=-(mass of water added inside cooler)*(2500) KJ |
April 20, 2018, 07:24 |
#22 | |
naman doshi
Rep Power: 9 |
Sir, i have written all equations required to write udf for both mass and source https://drive.google.com/file/d/18Gr...ew?usp=sharing W_ambient (is known -initial air passing in cooler) W_out (is known desired output of cooler) W_in (keeps on changing that is to be taken into account) |
Dry cooler - simplified cfd model | mech_01 | FLUENT | 0 | September 23, 2017 16:00 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
Huge file sizes when Running VOF simulation | aarratia | FLUENT | 0 | May 8, 2014 13:27 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 15:29 |
