#21 | |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Here's a quote from the CFX documentation:
#22 |
Gert-Jan
Rep Power: 27 ![]() |
I am not really interested in the exact geometry (and prefer not to open a zip file from this forum from someone I don't know at all).
I'd rather see a sketch/drawing of the geometry and the physics that you want to include. Movements, fluids, solid, forces, etc. And show what the fuid is that is not allowed to move. Then we can think of how to model such a thing. |
#23 |
Ali
Rep Power: 6 ![]() |
Dear Glenn,
Actually, I choose the immersed solid because I could rotate it around three axes (x, y and z) while it moves along these axes (x, y and z). Therefore, if I cant do such the simulation with immersed solid, can I do that with the solid domain (since, solid domain can interact fluid domain properly), Or you recommend me to use another application such as Fluent or COMSOL? |
#24 | |
Ali
I attached a sketch of the geometry. And about physics of the problem, I should say that there is no complicated conditions. I just want to simulate the movement of water and air inside the immersed solid, while immersed solid moves with sinusoidal movement. |
#25 |
Gert-Jan
In one of the previous threads you said: "the two-phase fluid doesn't move with movement of immersed solid". If you think it won't move, than ignore it and include it in the solid. Only make a correction for the density.
But now you say you want to model "the movement of water and air inside the immersed solid, while immersed solid moves with sinusoidal movement". Nevertheless, If you want to model fluid inside and outside simultaneously, I would not do that using immersed solids because of Glenn's comment. Probably through deforming meshing. Moreover, if you know the sinusoidal movement, then ignore the water on the outside, and only model the two- phase flow inside. |
#26 |
urosgrivc
Rep Power: 11 ![]() |
hello,
Do it like this: You just need ONE domain for this problem Get rid of the outermost domain and the solid one and set the air and water in the same domain, just a simple cylinder with proper initial conditions (both are fluids) there is no solid in this example if I understand corectly. Then just make a cylinder half filed with water half air and set outer walls to a sinusoidal velocity (you don't need a solid for this) include gravity and correct models maybe even surface tension when you see it is working. begin with a really small timestep or even a steady-state solution because two-phase simulations like this tend to explode at the beginning (first few timesteps are problematic). You will need to play around with the models to get good results as air will be mixed with water a lot Consider using symmetry, this will help the computational speed, if the movement is just sin up and down then this is an axisymmetric problem and a 2.5D can be used this would be very fast to compute, doing this in full 3D will be a massive job. Regarding the mesh, I don't think you will see a lot of improvement in CFX using hex mesh. Hex mesh or even pure 2D axisim in Fluent would make the simulation a lot better but CFX isn't affected much. Do put some inflation on the walls though. Have fun and experiment... Last edited by urosgrivc; February 11, 2020 at 04:35. |
#27 |
Ali
Thank you Gert,
Yeah, I want to simulate movement of water and air, but the fluid domain (water and air) doesn't move correctly with immersed solid. Therefore I cant simulate it correctly. About considering the fluid domain as a solid domain or immersed solid. In my case, I suppose it doesn't work. Because, I need a 3D render of water.Volume Fraction, which is not available for solid domains. And about ignoring outside space and immersed solid. It doesn't work too, because I know the exact movement of the solid (immersed solid), not movement of the fluid (water and air). Actually, this is the movement of the solid which acts on fluid. |
#28 |
urosgrivc
Stop talking about immersed solid, what immersed solid do you have?
The container? or what do you think an immersed solid is in your case? The container is not part of the fluid simulation, just the velocity of the walls of the inside of the container is the part of CFD simulation. Again this is a ONE domain multiphase simulation "And about ignoring outside space and immersed solid. It doesn't work too, because I know the exact movement of the solid (immersed solid), not movement of the fluid (water and air). Actually, this is the movement of the solid which acts on fluid." again this is not an immersed solid Only Walls act on the fluid not the solid as a volume so there is no solid domain needed if you know the movement of the walls and why did you have additional "space" in Attached Thumbnails, What does that do? I think that you need to rethink this or I dont understand what you are doing Is your plan to simply mix the air and water together by moving the container up and down? |
#29 |
Ali
Thank you urosgrivc for your complete and helpful explanation.
#30 |
Ali
So, I need to simulate movement along x, y and z axes and rotating around these axes (x, y and z), simultaneously. Do you think that I can do this with just one domain (fluid domain)?
#31 |
Ali
Dear urosgrivc,
The outer space is introduced, because the container need to immerse inside a fluid domain. And if I don't introduce it, CFX considers the fluid inside the container as the fluid domain. Moverover, mixing water and air is not my plan. I need to study on sloshing of water. |
#32 |
urosgrivc
isn't this exactly what you are looking for?
https://www.youtube.com/watch?v=oIFfPEWHkxw google -> vof sloshing tank cfx You need to set the domain to move so goolge-> domain motion cfx, mesh motion cfx You need to "fake" the container as it is not needed |
#33 |
Ali
Yes, this is kind of what I want to do. But as you can see in the video the fluid domain just moves along x, y and z axis. But, I want to rotate the fluid around x, y and z axes simultaneously, too.
#34 |
urosgrivc
I am sure it is possible to move it in any way you like.
I mean if 1+1 works why wouldn't 2+3? if you know what I mean it is the same thing just in other directions |
#35 |
Ali
Thank you dear urosgrivc,
There should be a way to do what I want. I just need to find it. |
immersed, solid |
Immersed Solid and FSI | Pierrm | CFX | 0 | March 26, 2018 05:36 |
Immersed Solid Valve Expressions | shzinwoyk | CFX | 2 | January 5, 2018 00:15 |
Flow over a flat plate as an immersed solid | hamed.majeed | CFX | 4 | September 8, 2016 14:40 |
Immersed solid, vs solid-fluid interaction to determine forces on a submerged solid | amrbekhit | CFX | 0 | January 8, 2015 16:39 |
Immersed Solid Momentum Sources inside function | Martinw | CFX | 1 | October 10, 2013 17:14 |
