naman doshi
Rep Power: 8 ![]() |
I want to do mass balance, there are 2 vents (on the wall) and a cooler(rectangular area inside room) all of the dimensions 0.5*0.5m while using CFD-post function calculator area both vent comes to be 0.25m^2 while area for cooler is 0.5 m^2
Q1. how is it possible?? Q2. how do i do mass balance analysis? simulations are done on cfx. both vents are given as opening. cooler as inlet with 5m/s velocity. fulid is - humid air. sst model used please help. thanks in advance edit- i found the reason for the wrong area basically it is taking both faces of the area hence 0.25+0.25m^2= 0.5m^2 also in function calculator mass is coming of order 10^-5 which suggest that #mass going in that area of cooler =mass going out that area of cooler. Last edited by namandoshi; April 11, 2018 at 04:35. |
M
Rep Power: 12 ![]() |
Can you add an image and maybe which expressions you used?
Gert-Jan
Rep Power: 27 ![]() |
It is very good that you check mass balance.
But you should already check your mass balance during the calculation. Therefore open the run in the solver manager, create a new monitor and select to plot all imbalances (mass & momentum). These should all go to zero, to assure mass balance. Alternatively create a monitor in the same way and plot the mass flows through the inlets and outlets. The sum should be zero. All these data are stored in each results file by default. So, also if you open a finished run, you can retrieve these data very easily. Much easier than in fluent, where I find this impossible ;-) |
naman doshi
#5 | |
naman doshi
Sir can you please explain step by step as I am working on cfx first time are this options in cfx-pre or solver? |
Gert-Jan
I expect my explanation regarding the imbalances is clear enough since I didn't mention the word CFX-Pre.
Just go through the steps I described. Read my text. |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
CCL CFD post: use of common perl function | Leackim | CFX | 1 | January 23, 2017 08:37 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 00:30 |
Using the same function for a number of locations in CFD Post | steady-state | ANSYS | 2 | May 9, 2012 05:26 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
