Somashekhar Kulkarni
Rep Power: 8 ![]() |
I am trying to simulate volume or bulk condensation in a cuboid type of enclosure. The image of the geometry is attached below. Initially, the enclosure contains air at 1bar and 120 deg. cel. The lower face is the inlet and all other faces are adiabatic walls. I plan to inject steam with a constant mass flow rate (for 120 s) so that it's partial pressure equals its saturation pressure at 120 deg. cel. Now I don't have a clear idea on how to model this problem so that volume condensation takes place. Is there any tutorial available or has any one done a similar simulation before? I'm planning to use the droplet condensation model in CFX.
Rep Power: 144 ![]() ![]() ![]() ![]() |
I don't recall seeing a volume condensation case in the CFX examples. Have a look at the tutorial examples in the ANSYS Customer webpage but I suspect you won't find one. Then contact ANSYS Support as they may well have an example of this available.
By the way, the water won't start condensing at the saturation pressure. You are going to have to super-saturate it to get it to form condensation. How much you have to super-saturate it depends on the nucleation sites in your gas volume. Welcome to the world of non-equilibrium thermodynamics ![]()
Gert-Jan
Rep Power: 27 ![]() |
I think you could get started with a 2-fluid apporach with air and steam-water combination. Look in the help for paragraph 1.2.2.3.4 IAPWS Equation of state
I think you need to use Steam4vl for the vapour-liquid combination. But I am not sure. Remember that it is an equilibrium model, meaning that CFX assumes equilibrium between vapour and liquid in each numerical element, with might be a fair first assumption. And you have to check whether if air interferes here. If not, you have to include the mass and heat transfer rates yourself, which can be a significant amount of work. |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
multiphase turbulance case floating error | harsha_kulkarni | OpenFOAM Running, Solving & CFD | 3 | February 18, 2016 05:06 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
volume fraction, Mass fraction and Bulk Mass flow | Dr.jones | CFX | 1 | January 25, 2006 04:32 |
