April 4, 2018, 03:43 |
Variation in refractive index
S.Abrol
Hello everyone.
I am new to using ANSYS CFX and am currently working on a simulation model on ANSYS CFX. It consists of a dome structure which is experiencing wind velocity due to atmospheric turbulence. So, due to the wind velocity, there would be minor fluctuations in the refractive index over the dome. I wish to add refractive index as a variable or an expression using which I can know the changes in 'n' because of the wind velocity. Thanks in advance for comments and advice. PS While trying to set up an expression for the same, I did find refractive index as an option under Definition---> Variable---> Reference Pressure---> Rotation Velocity Z---> Refractive Index but I don't know if I can use it or how. |
April 4, 2018, 07:02 |
Rep Power: 144 |
I presume you are using the refractive index for radiation modelling.
I thought refractive index was a material property, so you can try making that a CEL expression as a function of whatever you want.
April 4, 2018, 08:33 |
#3 | |
S.Abrol
I tried to make a new expression namely 'delta n' and I had selected the variable 'Refractive Index' as it's value. But I could not run CFX as it showed that the value of delta n should be in the format 'delta n = value'. |
April 4, 2018, 08:45 |
Rep Power: 144 |
The best place to learn CEL is with the CFX tutorials. They are available on the ANSYS Customer website, or the ANSYS academic website if you are a student.
The list of available variables are in the CFX documentation, in the reference guide in the section on CEL.
April 4, 2018, 16:36 |
Rep Power: 33 |
Try DeltaN instead
February 2, 2021, 16:20 |
#6 | |
John
Hey, Check out this in depth review of RI. https://www.opticsforhire.com/blog/r...optical-design John and Viktor |
ansys cfx, cfx, refractive index |
ANSYS ICEPak - setting refractive index | chris92jc | ANSYS | 1 | October 13, 2015 09:15 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 11:45 |
Refractive index of a solid | rsslnt | FLUENT | 0 | January 7, 2013 04:33 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 12:40 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 06:48 |
