Mass sources in CFX4.4
Old   December 5, 2003, 05:07
Default Mass sources in CFX4.4
Carl
Using user routine USRSRC of CFX4.4 I want to set mass sources. I look into the manual, there is something dealing with variable UMDOT and UMDOTO, but still not clear for me. My questions: How should I define the dimensions of UMDOT and UMDOTO? How these variables look like? It'll be very grateful if somebody could give some detailes about the questions.
Old   December 10, 2003, 01:48
Default Re: Mass sources in CFX4.4
Jeff
The mass source would be set in SU and SP like any other source terms, checking for IEQN to equal the equation number for Pressure (mass). The source SU will be in units of kg/s. See section 10.30.2.
Jeff
Old   December 10, 2003, 05:05
Jon
Not quite true.
You should always use SU for mass sources, even if they are -ve (sinks).
Old   January 10, 2004, 15:05
windhair
but should I add it as real value or dimensionless value, which means multipled by volume of cells? Thanks
Questions about Mass Sources jiguozhao CFX 20 January 29, 2020 12:08
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Mass sources Nikolaos FLOW-3D 1 January 10, 2009 01:22
Mass sources - help! Emmanuel Resch Siemens 11 May 29, 2008 11:20
CFX4.4 - mass residuals in 2D? Novak Elliott CFX 4 September 17, 2003 00:55
