March 31, 2018, 06:08 |
Using Perl's "Foreach" loop in CFXPost
Navid Mikaillian
Rep Power: 8 |
I am going to write a general script for gas turbine performance calculation. Let's say I have different domains in my model like Vane1, Blade1, Vane2, Blade2,... . (The names and number of domains can be different in different models) I am wondering if the domains can be treated as "Objects" of a model. I mean if a Perl script can go through all of them without knowing their names and count. For example by a "foreach" loop over the list of all domains: foreach $domain ($AllDomainsList) { ## Do something in $domain ## e.g. print its name! } One solution could be to publish a CFXPost report and then doing string manipulation over that text file... I know this solution... but I thought maybe someone knows a more direct way of having access to a CFX model objects. Cheers, //Navid Last edited by navidmkl2; March 31, 2018 at 07:33. |
March 31, 2018, 10:56 |
Navid Mikaillian
Rep Power: 8 |
Update!
Maybe i can try this one: http://www.eureka.im/4160.html I'll let you know the outcome. //Navid |
April 1, 2018, 01:05 |
Rep Power: 144 |
The perl and CCL are separate interpreters. By that I mean the file is passed through the perl interpreter which generates a larger CCL file, and the CCL is interpreted by CFX. The two interpreters do not interact beyond that. So as long as your proposed loop fits inside this structure it should be possible.
cfxpost, foreach loop, perl |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
