March 28, 2018, 07:52 |
Abnormal vorticity contour line in CFD Post
ShinYoung Jeon
I calculated 1.5 stage gas turbine. Mesh was generated in Turbogrid 18.2 and it is 4M hexa grid for each row. y+ is below 1 on blades surface. Boundary conditions is inlet total pressure and outlet static pressure, inlet total temperature. Wall is adiabatic.
The problem is vorticity contour of vorticity. I checked axial directional vorticity for user specified range to -4000 to 4000. Usually, I flow dynamics problem, especially using fine hexa grid, the countour line of any properties are smooth lines. But in this case, vorticity coutour line is irregular and show sharp border in mid range (-800~800). What is the wrong? in this problem? |
cfd, contour, gas turbine, vorticity |
[Gmsh] No cells read from file ".msh" | hwsv07 | OpenFOAM Meshing & Mesh Conversion | 5 | August 13, 2018 15:42 |
Labeling contour plots in CFD post | mujahidbadshah | CFX | 0 | April 20, 2016 03:25 |
Plotting the Viscosity Contour in CFD Post | ashtonJ | FLUENT | 3 | June 2, 2015 12:06 |
[OpenFOAM] could not open file .vtk in paraview | ali_atrian | ParaView | 8 | August 27, 2014 10:31 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
