November 24, 2003, 09:34 |
Optical Thickness
Hello CFX-Users,
I am setting up a model where I want to consider radiative heat transfer and CO2 and H2O vapour are definitely present. I understand from the manuals that knowing the optical thickness is important in selecting the most appropriate Radiation model. Does anyone know how to calculate the optical thickness? Thank you, Jonathan |
December 22, 2003, 13:25 |
Re: Optical Thickness
Using Beer's Law and curves from Hottel and Sarofim will do the trick for H2O and CO2. Siegel and Howell's text is very helpful - Thermal Radiation Heat Transfer.
Total Thickness of Inflation Layer | prikeyma | CFX | 5 | August 28, 2020 03:22 |
Momentum and displacement thickness: du/dy calculation | Josh | CFX | 13 | October 27, 2013 14:38 |
Calculating displacement and momentum thickness from Fluent | VSAndroid | Main CFD Forum | 0 | April 14, 2011 13:45 |
optical thickness | ehrenwirth | CFX | 5 | June 26, 2009 11:36 |
Max Optical thickness for Discrete Ordinate Modell | Thomas | FLUENT | 0 | April 13, 2005 07:13 |
