How to convert .dwg into .igs files?
Old   November 22, 2003, 09:30
Default How to convert .dwg into .igs files?
Juan
Hi all! Could somebody tell me how to convert Autocad geometry .dwg files into .igs files to be imported by CFX. Does Autocad have an option to do it or an additional soft is necessary?. Many thanks. Juan.
Old   November 24, 2003, 01:12
Default Re: How to convert .dwg into .igs files?
buyung
This is the way I know. If u have mechdesktop, open the *.dwg file in it and export as IGES file.
cheers BK
Old   November 24, 2003, 12:39
Ogbeni
You can not get *.iges out of Autocad, one way is to use Microstation to read your Autocad file and then export it as .iges, the other option which I use is Cadfix, you export ACIS out of Autocad, and then Cadfix to get iges. Either way, you need another program to get it out
Old   November 25, 2003, 07:45
Juan
Many thanks both Buyung and Ogbeni, I'll try these options. My problem seems to be solved.
Juan
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
