another unknown Pre error
Old   November 19, 2003, 07:25
Default another unknown Pre error
Louwrens
Anybody know what this means:
"SEVERE Operation 'writeCaseFile' failed with unrecognized exception."
and what to do about it?
It happens when I try to write a definition file from Pre.
Cheers
Louwrens
Old   November 19, 2003, 17:36
Default Re: another unknown Pre error
Hi Louwrens,
It sounds like a problem in CFX-Pre. I would contact your CFX support rep about it.
Glenn
Old   November 20, 2003, 02:32
Louwrens
I've been having quite a few of those lately...
Problem with these type of errors are you don't know "where" to go look to try and correct it, and the message itself doesn't give any info!
Old   November 20, 2003, 17:34
Hi Louwrens,
If it is a problem with CFX-Pre rather than your settings then there is not much you can do about it. Make sure you have the latest CFX-Pre patch installed - they cunningly released another patch for CFX-Pre after the July 24 patch and did not tell anybody about it.
Unfortunately, CFX-Pre is a bit buggy. You may be able to find a workaround by either importing CCL code into CFX-Pre. Alternatively only using CFX-Pre for domain and BC setup and setting up everything else in a CCL file and importing it into the def file with cfx5cmds might work.
Regards, Glenn
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 10:37
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
